Carl Bells RV7A N947CB
Date:  1-19-2009
Number of Hours:  4.00
Manual Reference:  None
Brief Description:  Shortening Magneto Wires & Mounting
I shortened the magneto wires on the right side of the engine and mounted them using Adel Clamps and tie wraps. I used heat shrink over the tie wrap were they touched the motor mount to eliminate chafing and some hi-temperature fuel line tubing as standoff spacers. I will get a close up of this the next time in the hanger. This has worked out well so far.
Mounting of the magneto wires
View of wire routing
