Brief Description: Installing the baffle rubber seals
I am almost done with the baffles; the last steps are the rubber seals that seal the gap between the baffle and the cowl and the cooling tubes for the magnetos and the alternator. Per the instructions I went with paper patterns first and then cut the rubber material from the patterns. After all the pieces are cut and in place they get mounted with large head pop rivets.
