Brief Description: Alternate air and induction mounts
I finished the air box today. The mounting brackets are epoxied in place with pop rivets used for the bracket mounting. This is slightly different then the plans, to allow the filter to fit better. The plans call for all brackets to be mounted on the inside, I mounted 2 inside and 2 outside and the filter fit right in. This was especially important for the rear mount, because of the angle of the inlet floor and the tight bend required to make it work. This was a real challenge to get it all to come together properly, and I had to make a number of pieces over.
