Carl Bells RV7A N947CB
RV 7A
Dwg 37
Rudder cable guides
I started with red rolled Perm-Flex tubing to get everything set and then switched to the straight 10" sections because I didn't like the curl from the rolled stuff.
Under the Whelen
Through the spar
RV 7A Home
2392
*Project Status*
Control Systems
Cowl and Baffle
Elevator
Engine Wiring
Fiberglass Finishing
Firewall forward
Flight Testing
Fuel Tanks
291
Hanger
Horizontal Stab
Interior & Upolstery
Paint Designs
Panel
Panel Design
Panel Wiring
Plumbing & Wiring
Propeller
Propeller
Upholstery-Interior
Vertical Stabilizer
Wheel Fairings
231
