Brief Description: More final fitting of the panel and brackets
Today I finished the attachment brackets for the panel including the bottom brackets that attach to the fuselage sides. After everything was clecoed in place the panel is not very strong and ridged. All that is left is the nutplates that attach the .063 aluminum insert panels and then cutting out behind them. This is going to be a pretty panel when it’s done, and hopefully very easy to work on, since each insert drops out with the instruments and EFIS attached.
