Carl Bells RV7A N947CB
RV 7A
Custom work
Push-pull rudder system
This is the preliminary set up for my one legged push-pull system. I wanted to make sure it worked and could swing through the full motion with no interference. It looks good, so next session I will go ahead and weld the horns in place.
Horns in place-still to be welded
View from the front
Mounting angle tie in to rollover brace
RV 7A Home
2392
*Project Status*
Control Systems
Cowl and Baffle
Elevator
Engine Wiring
Fiberglass Finishing
Firewall forward
Flight Testing
Fuel Tanks
291
Hanger
Horizontal Stab
Interior & Upolstery
Paint Designs
Panel
Panel Design
Panel Wiring
Plumbing & Wiring
Propeller
Propeller
Upholstery-Interior
Vertical Stabilizer
Wheel Fairings
231
