Carl Bells RV7A N947CB
RV 7A
Fiberglass
Right wing tip installation
This was all straight forward cutting and fitting work of the tips. I used some shims on the trailing edge rib to get a match in shape to the aileron.
Adding tip brace for tip
Right tip installed, left one started
Wing tip closing rib
RV 7A Home
2392
*Project Status*
Control Systems
Cowl and Baffle
Elevator
Engine Wiring
Fiberglass Finishing
Firewall forward
Flight Testing
Fuel Tanks
291
Hanger
Horizontal Stab
Interior & Upolstery
Paint Designs
Panel
Panel Design
Panel Wiring
Plumbing & Wiring
Propeller
Propeller
Upholstery-Interior
Vertical Stabilizer
Wheel Fairings
231
