Carl Bells RV7A N947CB
Date:  6-12-2007
Number of Hours:  6.50
Manual Reference:  Dwg 5 & Section 5
Brief Description:  Right Elevator Stiffeners
Worked on the right elevator today because I am still waiting for the Akzo epoxy primer from Aircraft Spruce. I decided the Variprime is just not tough enough and will not stand up to solvents or gas, so hence the switch. I don’t know why folks use this stuff, epoxy is much tougher. At any rate I made all the stiffeners for the right elevator, buffed the edges and matched drilled them to the 701R skin. Very boring but important work, so I took my time and made all on them to perfection. Maybe the primer will show tomorrow and I can prime and then start doing some assembly work.
Match drilling stiffeners
After trimming stiffeners & drilling
Drilling right the elevator
