Carl Bells RV7A N947CB
Date:  6-3-2007
Number of Hours:  6.00
Manual Reference:  Dwg 6 & Section 6
Brief Description:  Vertical Stabilizer
Since it was raining and I couldn't prime the HS parts I decided to start the VS. This went faster then anticipated. All the part came together well and the fit was good. I filed all the edges and buffed the with a Scotch Brite wheel. The spar reinforcement bar required quite a bit of clean up since it's a stamped part. The ribs need considerable fluting but the skin fit perfectly. Match tool parts are very accurate and it was just a great experience putting the piece together. Still need to dimple and de-burr the skins tomorrow. I hope to prime all the HS & VS part together on Tuesday and start riveting this week. It will be nice to get some riveting under my belt, I haven’t touched a rivet gun in 10 years. I plan to start with low pressure and carefully learn my way into it again.
VS frame parts after drilling and fluting
Clecoed together for fit
Skin on and drilled
Skin on and drilled
