Brief Description: Squaring, Leveling and adjusting fuselage
I noticed that the slight curve in the fuse side vertical members from welding caught me off guard. It was straight 2 days ago... Then I noticed that although I measured 26" across the bottom of the fuse, and 26" across the middle of the fuse, the dimension across the top was...um...(how can this be?) 24". So, got out squares, levels, plumbs, and torch, and made it all right again. Gentle heat persuasion opposite the welds did most of the work.
