Brief Description: bring together aft fuse and join LH to RH longeron
Proceeded with utmost caution, aligning, squaring and levelling everything as I brought the tail together. Heated longerons so they would bend in the right places, brought it all together, and then used 4.5 in grinder to nibble away at the saddle that the tailpost gets nested in. Fair potential to screw up bigtime if you go too fast. I got it all together, it's straight, and the airplane is only about a quarter-inch shorter than spec'd.
