CON'S WEB SITE
Date:  6-20-2015
Number of Hours:  7.75
Brief Description:  Air Vent Installation
Lots of time and not much to show for it. I fit and drilled the air vents to the brackets and riveted the brackets to the fuselage. I need to place an order for some AN365-832 nuts as I can't find the ones that came with the kit. I apparently used them elsewhere or I never got them. I cut twelve backing pieces from .032 and drilled them to #30. I mixed up some proseal and sealed and riveted the NACA vents to the fuselage. I started to work on the canopy, but I want to do some research first. I moved on to the battery box.
Beginning to Shape the Vent
Vents Mounted to Bracket
NACA Vent Sealed & Riveted
