Busy at work, hadn't had a chance to sleep when home much less work on the plane. Didn't feel like working on the plane, but it won't build itself. Drilled the holes for the static ports per plans. Should have moved them forward slightly as the Safair ports hit the bulkhead flange. Was just going to seal them to the fuse walls, but decided to use two rivets. Didn't get the holes vertical and slightly dented the fuse. Noticed I drilled holes in the wrong places some time ago for the seatbelts. Ordered new brackets and bolts to use as a doubler to fill the holes. The plane may not build itself, but at least it doesn't take two steps back without my assistance.
