Not much progress today. I did manage to get pictures of the Air Flow Performance fuel pump and filter work I did yesterday. I also mounted the Andair fuel selector valve to the plate but I need to purchase some longer #8 screws. I removed the bar connecting the sticks and adjusted the length to be just over 18.875" center to center. I reinstalled the bar and now the sticks are parallel. My Avery washer wrenches are worth their weight in gold. I got the rudder bar/brake pedal assembly out of storage (my music room) and installed the cotter pins. I put the rudder bar in the next to furthest forward set of holes and climbed in the fuse to test the distance. It seemed about perfect, so I bolted them in. I was going to work on the brake lines or perhaps install the static ports but after I did a couple of hours of yard work, I never made it back into the garage.
