I cut and drilled the F-782D angles. I will notch them after I get everything fitted. I temporarily bolted (finger tight) the F-7114 Gussets in place with some hardware store bolts. I drilled the gussets using the holes in the side skins as guides. I am trying to get some things ready to prime this weekend.
