I squeezed the two rivets attaching the sidewall braces (I forget the part number) to the lower longerons as the rivets are not accessible once the forward bottom skin is attached. The squeezer cocked over on both of them for some reason. I couldn't find any interference. I drilled one of the rivets out and then reset a new one with the gun and bucking bar. I touched up the other rivet using the same. I found some small pieces that I have yet to prime, so rather than painting in the dark, I moved on to the aft canopy decks and finished the edges. Not a lot of progress tonight.
