My Tosten CS-8 grips arrived today. They look and feel great and I am very pleased with them so far.
I clambered back under the fuselage assembly and drilled the F-750 Aft Baggage Side Covers. I also drilled the 7/16" holes in the bottom forward skin for the vent lines. I removed the F-724 and F-722 vertical and horizontal ribs and edge finished and deburred the holes. I also drilled the holes in the vertical ribs for the static lines and rudder cables. I want to check everything over before disassembling the structure to prep it for priming and assembly.
