I used my new 90 degree drill attachment to drill the center rudder pedal brace to the firewall. I then drilled the floor stiffeners to the bottom skin with Ginger's help. It was a bit of a pain in the arse. The center lines on the two innermost stiffeners didn't line up with the holes in the skin when the stiffeners were clamped to the angled braces on the firewall. I moved them over a smidge until the lines appeared in the skin holes and fabricated a spacer to fill the spaces between the stiffeners and the angled braces. I fit the horizontal baggage comparment ribs and drilled and clecoed them to the skins. I then clecoed the rear baggage walls to the ribs and called it a day.
