CON'S WEB SITE
Date:  9-16-2013
Number of Hours:  2.75
Manual Reference:  8-2
Brief Description:  Began Assembling the F-704 Bulkhead
It is quite the pucker factor to drill into anything gold in color. Particularly when the pieces are specifically matched to the completed wings behind you. I measured for what seemed like a good hour before I began to drill. I stopped to check one last time and discovered that I had incorrectly marked the center line of the forward (F704-A) bulkhead. I caught my mistake in the nick of time and proceeded to measure over and over again for slightly less time than eternity. I finally got the holes drilled. In the four holes in F704A/B, I substituted the slightly larger SB625-8 for the standard SB625-7 snap bushings. At this time, I am not exactly sure what amount of wiring they will need to contain, so I erred on the side of caution. I stopped for the evening as I want to look at a few build logs before I proceed.
Installed SB625-8
Installed SB625-8
Snap Bushings Installed in F-704A/B/C/D
