Brief Description: Bent FL706B and Drilled FL706A to Spar
I bent the FL706B to the prescribed 6.3 degrees in my bench vise and checked the bend with my Smart Tool (it worked just as well to check it to the flap). I drilled the FL706A brackets to the spar and FL706B and then spent the rest of the evening devinyling, edge finishing, and deburring the flap parts. I still have quite a bit of that to do before I try to prime everything this weekend.
