I finally got around to riveting the aileron brackets in place. I had two rivets that I didn't like, so I drilled them out and made the situation worse. I placed an order with Aircraft Spruce for some larger rivets and will use them instead. Since I was going to have to pay $$$ for shipping anyway, I went ahead and ordered my Dynon pitot/AOA, some stainless 6-32 screws, a matching tap and a #36 drill bit. They will probably arrive Tuesday and I can get the pitot drilled to the mast and then rivet the mast to the skins. I drilled the aileron and flap seals to the skins and spars. I need some days without torrential rains so I can finish priming all of my parts. The flaps and ailerons are ready to rivet if I can ever get them primed. I also need to get the car dusted off and sold so I have room to build the fuselage.
