Brief Description: Fuel Tank Root Rib Access Plates & Rings
I used the flycutter to cut the access holes in the root ribs of the fuel cells. I am using the capacitive fuel senders and flop tubes so I used the solid T-411 plates and drilled the plates and rings to the ribs. I dimpled the ribs and countersunk the rings and attached the nutplates. I had to order some things for the Cessna from Aircraft Spruce so I had them throw in some AN470AD6 rivets. I will used them to close the tooling holes in the outboard ribs.
