Brief Description: Fuel Tank Drain, Cap and Vent Tube Clip
I constructed the vent tube clips from some scrap aluminum and wrapped them around a 1/4" drill bit to form the loop. I backriveted the fuel cap ring making sure that I used a slightly longer rivet to attach the vent tube clip. I had to bend the clip slightly to make enough room to backrivet it. I used the squeezer to attach the tank drain.
