I finished matchdrilling the leading edge ribs to the main spar and labled everything before pulling it all apart. I primed the rear spar components using the Stewart System for the first time. I really like it so far. Only time will tell how well it holds up. I then riveted the spars together. I removed the vinyl from the inside of the leading edge skins and clecoed the ribs into the skins.
