I purchased two more boxes of 1/8" rivet washers and a mini die grinder from Lowes. I glued the washers to the remaining holes in the tips. While letting the adhesive set, I ran over to Joe Tierney's house and picked up some foam, West System 403 and some glass. His RV7 is really coming along as he was working on the front baffle when I arrived. I came back home and riveted the elevator tips to the elevators. I used JB Weld to attach the fiberglass to the lead counterweights as recommended by Bob Wooley. I have one proud rivet on the bottom of the right elevator but I think when I glass everything it should be ok.
