Brief Description: Continued Fabrication of Rudder Stiffeners
I finished the rough cuts of the rudder stiffeners today. The bandsaw works well for this. You don't need a "metal blade" to cut the aluminum. The more coarse wood blade tends to not fill with metal as easily as a fine "metal blade." Keep a sacrificial piece of wood under the aluminum and the blade will "clean" as it passes through the wood. The wood also keeps the aluminum from catching on the blade and putting a bend where you don't want or need one.
