Brief Description: More Servo Wiring, VP-X Pro Mount
I reviewed the Skyview Installation guide on the Dynon website (downloaded it to the iPad). It differs from the instructions that arrived with my servos, as it clearly shows all of the servo wires pinned to the dsub connector. They (as in red, black, and yellow) get split out at the forward end of my wiring run. I thought this might be the case, but wanted to get it from the horse's mouth. I next got out the VP-X Pro box and mounting brackets. I decided that I would cut two pieces of angle and rivet them to the subpanel ribs. I drilled the mounting brackets to the angles and enlarged the holes to accept AN3 bolts. I forgot to "cheat" the holes slightly away from the leg of the angle to allow room for a socket. I got lucky on the forward most mount, but the aft mount will require a thin wall socket or open end wrench. I hope to not take it in and out once it is mounted, so it shouldn't be the end of the world.
