Brief Description: Canopy Frame Latch Adjustment and Splice Plate
Pete hung out while Kecia was in her Tax Accounting class again. We worked on adjusting the canopy frame latch mechanism as it was pretty tight and hanging up. We adjusted and bolted the latch rollers and then riveted the F-631 to the side rails. We drilled the four bottom holes in the C-704 plate and then matchdrilled them to the F-631. Next up will be countersinking the holes for the AN-426 rivets and riveting the frame together.
