CON'S WEB SITE
Date:  9-24-2017
Number of Hours:  3.00
Brief Description:  Lower Empennage Fairings & Static Tubing
Didn't get a lot done today. It took me a while to get the rubber gasket fitted to the lower empennage fairings. I removed the upper fuselage skins so I could get the tail strobe wiring, elevator trim wiring, and static line run. I then cut five pieces of 1/4" ID tubing and slipped it over the static tubing where the zipties would secure it to the bulkhead. I secured the static line and called it a day under the pretext of doing some "research."
Rubber Gasket Lower Empennage Fairing
Static Line Secured to Bulkhead
Zip Ties on Static Line
