CON'S WEB SITE
Date:  9-9-2017
Brief Description:  Lower Rudder Cap
I read a lot of Mike Bullock's build log today and watched the talking heads on TV pontificate on how horrendous the hurricane is going to be. I finally made it out to the garage with the idea that I would get the lower rudder cap fit. My fiberglass cap had a faint line in the shape of a finished cap. I took some measurements and found that if I cut along the line on the cap, it should work out well. I traced the line with my blue Sharpie and broke out the respirator and Rotozip. I couldn't slide the cap into place with the rudder mounted, so I unbolted the rudder. fit the cap, and hung the rudder again using my Avery hinge pins. I need to do some more research on how much clearance I need between the cap and the tailspring as right now as it is pretty close. Sanding the cut lines should result in slightly more clearance.
Marking the Cut Lines
Checking the Lower Rudder Cap Fit
