I purchased another set of F631A (I think that's the correct number) canopy frame bows to replace the one I drilled in the wrong location. I tried to get by with only using one of the new pieces, but gave up and decided to use both new pieces. I got them where I think they are "close enough" and drilled the side frame rails to the bows. I took everything apart and was going to prime the pieces, but I was running out of daylight. According to my log, today's work was done the first time back in June. I need to start making better progress if I ever want to fly this thing.
My Ray Allen flap position sensor arrived today along with my Dynon Skyview ADAHRS. I also ordered some steel AN fittings to use at the firewall for the fuel lines but I need to get some different washers. The ones I ordered are humongous. I ordered threaded rod and clevis for the position sensor from a hobby store and it arrived awhile ago. I hope I already have the correct size adel clamp, and I should be able to get it installed soon.
