CON'S WEB SITE
Date:  11-13-2016
Number of Hours:  3.00
Brief Description:  Safety Wire the Servos, Crimped Connectors
It took me forever to get somewhat acceptable results with the safety wire. The pitch servo, although not perfect, was not too bad. The third bolt on the back of the roll servo in the wing was a royal pain. I next began stripping the servo wires and crimping the pins. The Dynon instructions have the red, black and yellow wire run separately from those in the dsub connector. I did a little research on line, and it appears that I can connect all of those wires at the servo dsub as long as I remember to separate them forward. In other words, don't run all of the wires into the network hub. Going to do some more research to confirm.
Safety Wire on Pitch Servo
Safety Wire on Roll Servo
Pitch Servo Dsub in Progress
