Brief Description: Cut Holes in Side Skin for Canopy Release
I only had a brief amount of time before work today, so I wanted to get the holes drilled and cut in the fuselage for the canopy release handle. I photocopied the portion of DWG48 that contained the template, cut it out, and taped it to the side of the fuselage. I drilled the holes and then used a file to square off the openings. Although it looks better in real life than in the pictures, I will probably do a little more filing during my next work session. It is "close enough," but it can be better.
