Brief Description: Riveted the Aft Deck to the Fuselage
I primed the spacers and aft deck and riveted them to the fuselage. I then riveted the F-709 Bulkhead to the deck. I finished the holes in the F-757 gussets and drilled the gussets to the longerons and F-721B side rails. I still need to prime and paint them so I did not rivet them to the fuselage. I drilled the F-695 gussets to the main longerons and angle frame of the firewall. I had to "shave" a little off the front of the gussets so that the sides lined up with the longerons and firewall. I tried to squeeze the rivets but it was easier to just shoot and buck them. I marked the location for the shoulder harness anchors and drilled them to the longerons. I removed them and put them away as installing them now would interfere with riveting the skins.
