CON'S WEB SITE
Date:  11-20-2013
Brief Description:  More Outer Seat Ribs, Misc Fuselage Fabrication
I took last night off to watch a friend's son wrestle for his Junior High School Team. I have watched Dalton wrestle several times and he has spent less than 30 seconds total on the matt. Last year, only one person scored any points on him and that was when Dalton released him to practice a different move. He has won the state "Triple Crown" several times. The kid is a beast and humble to boot.
I started back on the outer seat ribs tonight. I am not sure if I can rivet them into place now or need to wait. I read ahead in the plans but didn't see where it mentions them after it tells you to drill them. I will check a few build logs tonight.
I moved on and fabricated the F-631E plates, the F-732D angle (I squeezed it in my shop vise to get the 88 degree bend), and the F-732E angles although I didn't drill them.
The weather looks like it may be good this weekend. I need to get the aft fuselage assembly primed and riveted.
Holes Marked for Drilling
F-631E Drilled
F-631E Drilled
