CON'S WEB SITE
Date:  11-1-2013
Number of Hours:  3.00
Manual Reference:  8-6
Brief Description:  Center Section Corner Ribs and Drilling
My spar spacers from Bullerent.com arrived today. I need to run by Home Depot and pick up some 7/16" bolts to temporarily bolt the F-704 bulkhead together. I marked and cut the F-623 corner ribs after reviewing the great pics on Brad Oliver's excellent rv7factory.com. I drilled the F-623A forward and aft attach strips and final drilled the bottom skin to the assembly. I also drilled the holes in the ribs and bulkheads to final size.
Bullerent.com Spar Spacers
F-623L Drilled and Clecoed
F-623A Aft Attach Strap
