My fuse kit is supposed to ship this coming week, so I need to get the wing skins done. First, I needed to secure the wiring to the landing and taxi lights. I decided to use an AN3-16 bolt with a WDG-3 Adel clamp to hold the wires secure out over the hole in the spar. Unfortunately, the -16 length bolt is just a bit short for my liking so I will need to line the hole in the spar with rubber tubing or something similar to prevent chafing. I tried using a portion of my SafAir static line but it is too inflexible and kept popping off of the spar. I will try some rubber hose from Home Depot or perhaps order something from Stein.
My order from ACS arrived on Thursday, so I had my rivets to complete the bottom skins. I finished the right wing, and will finish up the left wing tomorrow. I could finish it this evening, but I agreed to take call tonight.
