Well, I didn't get the left tank finished. I went to our EAA meeting and then found out the guy checking the transponders was at the airport so I had the Cessna checked. Of course, I then had to go flying.
I did get the attach angle riveted in and the flop tube installed. I formed the fillets around the end ribs and encapsulated the rivet heads before calling it quits. I'll give everything a once over tomorrow and install the rear baffle, z brackets and access plate. So much for priming the leading edge-maybe next weekend.
