Brief Description: Assembling Right Wing Structure
Heavy downpours wreaked havoc on my plans to prep and prime all of the main wing ribs. I only managed to get the right wing done in between showers before retreating to the garage and riveting them to the main and rear spars. I remembered to keep the manufactured heads on the rib flanges and the riveting turned out pretty well. I only drilled out one rivet and managed to do so without causing any damage to the rib or spar. I constructed both wing walk doublers using snips and my bandsaw. I then clecoed the bottom skins to the ribs.
