I spent the evening working on the stall warning assembly. I prepped and dimpled the doubler plate, cover and riblet and drilled and filed out the area between the two holes on the leading edge where the vane will protrude. I need to cut the aluminum angle that will form the arms for my wing stands before Saturday as Joe Tierney is coming over to help get them set up. Lots to do in the garage to make room before then!
