Brief Description: Chasing Master Warning and Caution Lights
In running through the G3X Configuration and Tests, I found that testing the Master Warning and Caution annunciator lights did not work. I retrieved the wiring diagram and found the wire does not go to ground, but to power. Re-did this part of the annunciator light, rested and worked.
At the same time, pulled out the wiring diagram for the IBBS 4-AH backup battery for the Low Volt annunciator. This was also mis-wired, it should be taking power from one of the three wires which the IBBS powers during backup operation. Fixed this too.
Hi there..
Re-wiring the Master Warning, Caution and Low Volt
