My RV-8 Build Log
Date:  6-27-2017
Brief Description:  Rudder Lighting Continued
Installed the Aeroleds Sun Tail light on the rudder bottom fairing, the wire transits through the vertical stab, through a grommet to protect the wire. This makes it possible to remove the VS by disconnecting the light at the Molex connector, and pulling the wire back through the VS since the moles will pass through the grommet bushing.
SUn Tail light installed on Rudder
Wiring run for Sun Tail Light
Rubber Grommet Protection for Rudder Lighting
