My RV-8 Build Log
RV-8
RIght Side CHT and EGT
Routed CHT and EGT sensor wires from FW penetration to engine right side.
Use cable ties on the three butt splices per Kavlico sensors as a form of strain relief...
Not really sure this is the final solution.
Engine RIght SIde CHT and EGT sensor wires
Added Cable Ties to Butt Splices
Engine Right Side
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
