Brief Description: GEA 24 Stand-Off and assoc wiring
Created (4) 1/4" length spacers for the (4) mount bolts of the GEA 24, attached the GEA 24 using the spacers and mounting plate, which created sufficient clearance for all of the GEA 24 connectors, routed the CHT and EGT sensor wires through the firewall, using the hole previously drilled for the Van's standard manifold pressure line, but not using, instead of drilling another hole.
