During the test fitting of the connectors to the GEA 24 engine monitor, realized the two connectors at the base of the GEA 24 (forward side of GEA 24 as mounted) creates an issue with the connectors.
There is just not sufficient room to install the bottom two connectors. Decided to create a stand-off mounting plate to attach to the existing mount brackets.
