My RV-8 Build Log
Date:  10-15-2014
Brief Description:  ELT Location
Decided to locate the ELT in basically the only place possible, where it will be both readily serviceable and near the antenna.
• Measured and cut two 3/4" angles to create the bracing needed to mount the bracket supplied with the ELT.
• Located where the ELT will mount on the braces, match drilled holes to the pre-drilled holes on the supplied bracket.
• Deburred and cleaned up the braces.
• Attached the brackets to the braces using AN8R8 screws, washers and nuts.
• Test fitted in the plane the assembled ELT / brace combination.
• Tested all of the components to ensure there was no magnetic interference as this is in the same area as the two magnetometers.
Here's where the ELT is going
