My RV-8 Build Log
Date:  9-29-2014
Brief Description:  IBBS Bracket Redo
After locating the IBBS and brackets on the floor of the RV8 under the right console, I figured out that getting to the location to set the CS4-4 rivets would be difficult due to stuff already in place. I decided to build new brackets taking into account how I needed to set the blind rivets for securing the brackets to the floor.
• Measured and cut new 3/4" angle, four pieces of equal length.
• Combined two of the cut pieces to make a single bracket, match drilling the pieces for securing with AN470 rivets. Different from the first attempt, the two angle pieces are mated without over-lapping at the 90 bend, these are simply mated flush.
• Located the holes for the IBBS, matched drilled.
• Located the holes for the matching nut plates, drilled the #40 holes for attaching the nut places.
• Countersunk the rivet holes for the nut plates.
• Riveted the nut plates to the bracket.
• Test fitted the new brackets to the IBBS.
Making new brackets for IbBS
Bracket #1
Bracket #1
New IBBS brackets for securing under right cionsole
