Made connections to engine starter switch in fuse to starter contactor.
I am placing the 60A master CB on the panel to the immediate right of the ignition switch, for several reasons. (1) it is longer than the rest of the CB so it does not easily fit on the buss bar where the SWB and SB is located on the right console (2) I am installing 2 USB double sockets, one for the pilot position, the second for the nav position. Each of these will be powered without having to switch the master to the 'on' position, so iPad, iPhone, etc. can be used.
Made the jumper wire from the 60A CB to the SCB/CB right console panel.
