My RV-8 Build Log
Date:  6-15-2016
Brief Description:  Baffle Air Seal
Cut the rolled air seal material in 3" width, and cut to length to fit each cylinder baffle. The idea is the air seal will over lap at the cylinder baffle joints so each baffle can still be removed if needed.
Located #40 holes ~ 2" apart, final drilled #30 for the large blind rivets.
Cyl #1 and #3 Air Seal
Air Seal Split at cylinder baffle line
Ready to Rivet?
Ready to Rivet?
