Brief Description: Engine Control Cables Installation
Installed the Throttle and Mixture engine control cables to the appropriate levers of the Bendix RSA fuel servo.
The Prop Governor bracket requires adjustment. The control cable is supposed to pass thru the bracket when connecting to the lever of the governor. The prop governor should default to high rpm - fine pitch? Assuming course pitch is low rpm.
Removed prop governor from engine, will need to remove safety wire, unscrew the 6 screws, moved the bracket, and then reinstall the screws, I think it was 8 - 12 inch pounds.
Installed new safety wire and will install tomorrow.
